It is currently Sun Jul 27, 2025 6:57 pm
PostPosted: Tue Aug 24, 2021 4:18 pm
I was concerned about fitting Schertler tuners with the oval backplates and getting them to line up well - if they didn't they would look pretty sloppy.
They have no straight lines to line up, no good reference, so came up with this.
Just tuners in, sharp awl to mark for pilot holes, tape off and screw on tuners.
Even if the lines drawn go slightly off (as with RHS above), able to line up reasonably well.
Are there any other solutions people use?
These users thanked the author Colin North for the post: Pmaj7 (Fri Aug 27, 2021 1:53 pm)
PostPosted: Tue Aug 24, 2021 5:28 pm
I prefer the opposite look, where instead of the screws being in line, the tuners shafts are in line with each other at right angle to the center line. I just use the bottom of the saddle and hold it against the square gear housing, and punch the holes very carefully before drilling…
These users thanked the author meddlingfool for the post: Pmaj7 (Fri Aug 27, 2021 1:55 pm)
PostPosted: Tue Aug 24, 2021 6:07 pm
Same as Ed. Easy to do with a small straight edge.
These users thanked the author SteveSmith for the post: Pmaj7 (Tue Dec 13, 2022 1:20 am)
PostPosted: Tue Aug 24, 2021 6:12 pm
If all else fails, build a jig.
PostPosted: Tue Aug 24, 2021 6:22 pm
First name: Stuart
Last Name: Gort
I wouldn't attempt this without a precision drilling jig.
I can make a precision jig so I always think in those terms.
Kevin Ryan taught me never to cut wood without pre-determining the outcome. His shop is filled to the brim with complex tooling to make only ONE PERFECT cut.
In this scenario....you make a fake headsotck....transfer your desired hole pattern onto the tool....mount the tuners on that and then have a very close look at that for approval....then you drill through that pattern with the prescrew sized drill.
Now you have a drilling jig with your approval to mount on the headstock and drill with. If I was going to do this often...I'd make it from aluminum and pressed in drill guides but one made from a solid hardwood should be good with just drilled holes as drill guides...at least for a few.
StuMusic
These users thanked the author Stuart Gort for the post (total 2): Pmaj7 (Fri Aug 27, 2021 1:57 pm) • Colin North (Wed Aug 25, 2021 2:51 am)
PostPosted: Tue Aug 24, 2021 8:07 pm
Hi Colin,
I like your solution. Simple and straightforward. No jigs to lose in the clutter.
These users thanked the author Clay S. for the post: Colin North (Wed Aug 25, 2021 3:01 am)
PostPosted: Wed Aug 25, 2021 2:55 am
Normally I prefer straight across too, but trying to hint at the original which had 3 on a plate tuners.
'29 L-0 probably replacement tuners -
PostPosted: Wed Aug 25, 2021 3:27 am
We use both methods and replace a LOT of tuners at least once a week. It depends on the shape of the head stock and/or how the manufacturer intended the guitar to look as to which method we use.
These users thanked the author Hesh for the post: Pmaj7 (Tue Dec 13, 2022 1:23 am)
Users browsing this forum: Bing [Bot], peter.coombe and 18 guests
